no
Removes or modifies the Bonjour Gateway Discovery policy settings
Syntax
no allow-service <BONJOUR-SERVICE-NAME> [local|tunneled] {service-vlans <WORD>}
Parameters
no <parameters> Removes allow-service rules in the selected Bonjour GW Discovery policy, based on the parameters passed
The following example shows the Bonjour GW Discovery policy ‘test‘ settings before the ‘no‘ command is executed:
nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#show context
bonjour-gw-discovery-policy test
 allow-service Printer local service-vlans 1-2 instance-name contains $Bonjour_Service
 allow-service Afp local
nx9500-6C8809(config-bonjour-gw-discovery-policy-test1)#no allow-service Afp local
The following example shows the Bonjour GW Discovery policy ‘test‘ settings after the ‘no‘ command was executed:
